Kamerad said:Why does it have to be used oil![]()
AmaTeX said:Did you have to heat the oil in the fuel line/tank or is its viscosity high enough for the pump to handle?
50/50 said:I'm shocked you're actually paying tax on it. I hope you're declearing that you are only producing a small amount of oil, because that tax rate is daylight robbery.
Georgew said:will modern commonrail diesels run on this?
lordrobs said:All looks like good stuff. I'm sure your probably sick of all the questions but i'll add mine anywayWhat kind of fuel economy are you going to be seeing compared to derv as it would have to be identical to be able to simply compare cost/l?
geiger said:Makes you wonder why diesel costs so much then. If your a registered fuel producer then why cant someone do it on a large scale and cut prices from what they are now.
You know a friendly chippie I take it
pinkaardvark said:So if you used standard unused vegoil say in purchased in 20L Barrels for a pound from Lidl's you could effectively just pour it straigh in?
