Interesting read Intel i7 7700k owner's
http://www.pcgamer.com/intels-tells-core-i7-7700k-owners-to-stop-overclocking-to-avoid-high-temps/
patient: it hurts when i move my arm like that.
doctor: don't move your arm like that.
Where does it actually say stop overclocking?
"We do not recommend running outside the processor specifications, such as by exceeding processor frequency or voltage specifications, or removing of the integrated heat spreader (sometimes called 'de-lidding'). These actions will void the processor warranty."
It is really saying that they can't identify any random temp spikes on their end, so they're assuming that these high temps are a result of bad overclocking. If they can't replicate the issue then that's about as much as they can say tbh.
"No, we tested this ourselves and we can't replicate the reported temperature issues, its all the users fault, our products don't have these problems"
Given the premium they charge for 'k' CPU's its a complete **** take to tell people not to OC.
AMD's most recent reaction to OC criticisms, IE with Ryzen, was to explain how best to overclock it.
Contrast that....
Edit... here it is....
WARNING: AMD processors, including chipsets, CPUs, APUs and GPUs (collectively and individually “AMD processor”), are intended to be operated only within their associated specifications and factory settings. Operating your AMD processor outside of official AMD specifications or outside of factory settings, including but not limited to the conducting of overclocking (including use of this overclocking software, even if such software has been directly or indirectly provided by AMD or an entity otherwise affiliated in any way with AMD), may damage your processor, affect the operation of your processor or the security features therein and/or lead to other problems, including but not limited to damage to your system components (including your motherboard and components thereon (e.g., memory)), system instabilities (e.g., data loss and corrupted images), reduction in system performance, shortened processor, system component and/or system life, and in extreme cases, total system failure. It is recommended that you save any important data before using the tool. AMD does not provide support or service for issues or damages related to use of an AMD processor outside of official AMD specifications or outside of factory settings. You may also not receive support or service from your board or system manufacturer. Please make sure you have saved all important data before using this overclocking software. DAMAGES CAUSED BY USE OF YOUR AMD PROCESSOR OUTSIDE OF OFFICIAL AMD SPECIFICATIONS OR OUTSIDE OF FACTORY SETTINGS ARE NOT COVERED UNDER ANY AMD PRODUCT WARRANTY AND MAY NOT BE COVERED BY YOUR BOARD OR SYSTEM MANUFACTURER’S WARRANTY
This information describes methods to change factory settings and operate the processor outside of AMD’s published operating specifications. Recipient understands that operation of the product outside of AMD’s published specifications will void any AMD warranty and that overclocking of the processor may impact its functionality and longevity
Finally some backlash from the **** TIM they've been using for the past how many generations.
This may give them a kick up the ass to start soldering again.
I really wish people would stop buying Intel's CPUs, they are a shambles of a company for enthusiasts and the sooner people stop seeking that last 5% performance at any price the faster real competition can return and we all benefit.
yeah I mean everyone should have been buying faildozer cpus for the last 5 years so we could have had lovely cpu bottlenecks right?
We do not recommend running outside the processor specifications, such as by exceeding processor frequency or voltage specifications, or removing of the integrated heat spreader (sometimes called “de-lidding”). These actions will void the processor warranty.
