- 27 Jan 2012
- The king of the north!
May take a little bit longer but a much cleaner way to do things
Ok I just managed to complete nearly an hour on Homeworld without any problems! So early indication is that the clean install has solved the issue.
Thanks for all the advice, this forum is priceless for the knowledge.
One more thing though. I have had system restore turned off forever as I used to think it was a resource hog, however this experience has made me think other wise, although once in about 6 years that I have had to clean install due to a software issue. Should I use the system restore in windows or do you guys use something else?
Thanks again for all the help
