- 28 Oct 2003
- Worthington-on-sea
Sweet! I'll keep an eye out.
Another question that sprung up. The stud adjacent to the front door partially covers the old lounge light switch. I've removed the switch but I'm left with the box partially exposed. What's the best way to fill this in before its skimmed over?
you wouldnt have had any problems with your casing then as 4x2 regularised finishes under 4. Betime youve got your plasterboard on and skim it works perfect followed by architrave. For a wall that size too I'd of deff used 4x2. Plus you only need 9.5mm plasterboards, use the 4x3 handi boards, or 6x3, set your studs/noggins out for them and its much easier to cut and board.Are you going to put the stud wall up to block up everything from the left of the door on the right hand side? Where will the door go?
Why on earth didnt you use 4x2?you wouldnt have had any problems with your casing then as 4x2 regularised finishes under 4. Betime youve got your plasterboard on and skim it works perfect followed by architrave. For a wall that size too I'd of deff used 4x2. Plus you only need 9.5mm plasterboards, use the 4x3 handi boards, or 6x3, set your studs/noggins out for them and its much easier to cut and board.
Looking good. Looks like you might have ordered a bit too much timber?
One thing i'll add that i dont think has been mentioned. When you come to put the plasterboard on, make sure you don't have any joins above the doorways, as these will crack.
One tip fix some skirting blocks to the bottom plate, between the studs, it will give a bit more fixing area for a deep skirting.
Not being rude, but why?
Looks a bit claustrophobic around the back there?
Is that a join I see above the doorway?
It'll be better to put the casings on so that the plasterer can skim up to them.
Is that a join I see above the doorway?![]()
It won't crack if it's taped properly, surely?
