Guys I was gonna be buying a gtx 670 windforce today but this is a bit off putting , is it just a matter of drivers or would I be better off waiting or going with something else ???
You all know the stuttering issue that Nvidia is trying to fix only occurs when Vsync is on or Adaptive sync is on. .
Deus Ex HR never seems smooth to me with my 680.
Out of interest have any of you tried forcing the card to the Maximum Performance power profile in any games in which you are suffering from stuttering?
It's in the Nvidia control panel and it set to Adaptive by default. If I recall correctly it ensures the card stays clocked at 1006Mhz at all times, only ever going higher for the boost.
Could be worth a go.
Does anyone know if the fifa 12 demo has this stutter issue?
Because I would like to see if it happens on my rig.
I dont know if anyone else can confirm, but for me, I will have the FPS locked at 60 as you would expect and then every so often a small drop is experienced to about 56-57 then back up but this produces a noticeable stutter in game.
Is this what others are seeing?
I'm not sure that's this stuttering issue. Does it stutter all the time?
It will do this quite frequently whilst playing (random times but generally within every 30 seconds or so), its distracting and very noticeable.
With my old 470 in, I dont have this issue at the same settings with the same games. I also notice that in Precision X I am getting drops in the core frequency not sure if this coincides.
Does it occur when vsync off? I haven't read enough about the issue (as I don't have it) to fully understand it.
Exactly what I was seeing, small frame drops that shouldn't make any difference result in something resembling a slide show lasting a few seconds.
