- 22 Mar 2009
Stock speed is a bit boring to be honest @ 3.50GHz (3.90 with Turbo) They should get 4.00GHz stock by now (4.40 with Turbo)
Indeed, they're starting to push the current tech to the edge. There will be a point (we may have started to see evidence on 22nm) where laws of physics don't allow current tech to progress past.
You are right according to the law, however it would be pointless trying to actually enforce that with Intel.
First of all they've no way to prove what voltage and clock speed you ran it at, and secondly even if they could you'd need to take them to court which would wipe out any financial gain.
It doesn't according to Intel. However according to UK law; specifically the sales of goods act 1979, EU directive 1999/44/EC and the actual warranty it does.
It's advertised as a K model so can be unlocked for overclocking, the specifications list 1.52v as the max volts so a reasonable person would say overclocking a K model chip as long as you stay within specifications like TJMax/Tmax/Vcore max is normal use and any failure would be because of faulty manufacturing as opposed to consumer misuse within the reasonable lifespan of the processor.
The key point is that it's advertised as unlockable multiplier upto 63*, so it is assumed that is meant to be used as a feature of the CPU.
Hahaha! What?! No. That's not how it works. That's like saying your car speedo goes upto 200mph but your car only does 150mph after modifications and you moan to Ford about it.
At no point have Intel said you can reach any overclock or advised that you should. You can't just go on what you expect to get out of it based on how the chip allows you to configure it. Intel (a long with me) will laugh in your face.
Intel have sold the chip as is, no guarantee of overclock, there's nothing wrong with it.
Many chips back in the day had completely unlocked chips, and I didn't get 6Ghz out them, maybe I should complain?
You sir, crack me up.
You sir need to learn to read instead of going off on a tangent perpendicular to anything I have said, of which at no point in this thread has congrugated around your imagined thesis of anyone complaining about unattainable overclocks.
P.S. I object to your tone, particularly considering the stupidity of your post. May I suggest in future when you throw disparaging remarks around you ensure you are correct otherwise it will again make you look mightily foolish.
Congregate
Probably more than 5% performance increase and not sure how many people expected impaired overclockability.
Also, if 1 year is truly such a short time to expect a good improvement, as you say, people wouldn't be this upset. But I'm guessing they've come to expect more than 5% performance improvement in over a years time, so I'd guess that's part of what their disappointed about.
This is exactly my point.
5% improvement in 1 year is disappointing.
I also bought a retail 2600k@£180 last week for my z77 board instead of waiting for IB. I am glad I did as my Antec Kuhler 620 would have been woefully inadequate.
My Ivy just arrived along with the other upgrade bits - moving up from Q6600. I hope I made e a good choice but, frankly, a 4.5GHz over-clock will be fine.
