Project T-REX (Paint It Black II).
Tomorrow I will start building a new PC that will get a lot of use next year.
I am not 100% sure what parts I will use as I have a lot of spares and will use what works best. I will list them in the post below as I build the machine.
Eventually the PC will be equipped with some next gen cards when they are available, there is a clue in the title.
The plan is to have two separate waterloops, one for the CPU and one for the GPUs. This will give me the chance to use my chiller on the CPU when needed. To start with there will only be one loop as the GPUs I want are not available yet.
I will be going more for function so please feel free to call my new build ugly, more so because it will be about 95% black in colour so no bright colours.
Parts List.
LD V8 case.
Asus RVE X99 Motherboard.
5960X CPU.
Samsung 850 Pro 1TB SSD.
Corsair AX1200i x2 PSUs
Corsiar Black PSU Cable kits x2
Corsair Dominator Platinum DDR4 (4 x 4gb) 3200mhz
XSPC Twin D5 Dual Bay Reservoir/Pump Combo
2 x AX360mm Rads
1 x AX480mm Rad
XSPC Raystorm waterblock
EK Water Blocks EK-FC980 GTX - Acetal+Nickel x4
EK Water Blocks EK-FC980 GTX Backplate - Black x4
Monsoon Chrome fittings
Various Koolance quick disconnects
Primochill Primoflex Advanced Tubing 16/10 - Black x4
More to follow as I add parts.
Thread Navigation Links.
Parts List.
LD V8 case.
5960X CPU.
2 x AX360mm Rads
1 x AX480mm Rad
, Hope they sort it out quickly for you
