Man of Honour
- 5 Jun 2003
- Falling...
^^ spot on.
Don't you think that water from the bathroom tap tastes better than from the tap in the kitchen?
Some of you guys are so lucky, I'm in South East London and our tap water is absolutely foul. Unfiltered it makes vile chemical tea. Sometimes when we run a bath our house smells like a swimming pool due to the chlorine (?) they put in it.
Cold water in bathrooms should be tank fed and as things can and do happen to stored water I wont even use it to rinse my mouth after cleaning teeth, use hot instead as its mains via boiler.
Tastes a lot better i think![]()
The other way around, kitchen water is nicer and always colder.
YES. I don't know what it is, always seems colder and fresher from the bathroom tap.
Depends on your house actually. In my house both kitchen and bathroom are fed from the same rising main.your upstairs cold water doesn't come from the the tank in the loft at all
it come from the same feed as the kitchen cold water and is at mains pressure.
the tank in the loft only feeds your water heater and then on to your bathroom and kitchen hot taps by mavity feed.
