Well, dont want this thread to get pruned...
A little update...
Have ordered the Carbon Fibre Vinyl as i have been told it will stick to the plywood..
£45 worth
thats how big the case is lol!
Have got the other side fixed on now... and the PSU switch and socket is mounted onto the back..
Heres what i have left to do
1. Cut out slots for CD/FDD drives
2. Glue and screw the sides on.
3. Fill gaps with wood filler.
4. Make/Find legs for it to stand up.
5. Fix the legs securely.
6. Cover in Carbon Fibre Vinyl.
7. Cut out Side circular window.
8. Fix acrylic inside the window.
9. Somehow work a way to secure the 12mm plywood side, maybe some latches.
10. Collapse with tiredness!!
All in 2 weeks, wish me luck, its gonna be madness.. Will try and get some good pics tomorrow though
Thanks for looking,
Mark
