Temperatures... how hot is yours?
6 Nov 2005
Aberdeenshire
Ok.. i'm bored waiting for the missus to get ready to go into town shopping... so...
It's 30c in the room just now, here's my temps, let me know yours!!
(according to Everest & Speedfan while running SuperPI 32MB)
Temp Inside case 15C (lovely cool air blowing out the back)
Motherboard Chipset 32C
CPU 37C
GPU 42C
GPU Ambient 37C
WDC 250GIG Sata2 35C
Seageate 160GB Pata 38C
Maxtor 80GB 28C
Fans on the case...
1x Fan on Enermax Liberty 500W psu
1x Akasa Amber 120mm in rear exhaust behind Artic cooler
1x 80mm? on Artic Freezer 64 Cooler
1x 80mm on Side window.. also blowing onto Artic Cooler and Ram
1x 80mm at front of case blowing over hard drive sandwich
1x ??mm stock fan on X850XT AGP card <---- noisey git! :mad:
Cant be too bad temps I suppose, would love to have silent water cooling though... By far the loudest component is the fan on the graphics card (still got the Stock AGP Powercolour ATi X850XT in just now)
CPU: 35
MB: 32
GPU: 48
HD: 32
CPU heatsink/fan is stock
stock fan on 1900xt
akasa 120mm intake at front of case
akasa 80mm on side of case, blowing towards cpu
a 120mm rear exhaust fan
CPU 51
MB 31
Blimey! This is the first time I have a decent PC in the summer and I haven't bothered at looking at the temps! Seeems okay though play loads of BF2 in the heat anyway. :P
Why not, i feel my comps alright on air. Its around 30 degrees in my house too.
According to MBM:
CPU: 37, around 45 after 20 min of Prime95.
Case: 33
According to Aerogate II fan controller:
CPU ambient: 34
Case:32.5
GPU:39.5
Got stock coolers on everything, running a XFX 6600GT, 3200+, 2Gb Ram, 400W Akasa PSU. Plus two extra case fans
According to SpeedFan...
CPU (A64 [email protected], 1.425V): 36C going to 44 under load
PWM: 45C
NB: 45C
GPU (X1800XT): 47C
HDs: ranging from 31C to 34C
Thats with a Ninja on my CPU, a VF900 on my X1800 and two 120mm case fans:)
Not too bad considering I'm sweating my balls off here!
Room temp is about 20C I guess
Idle temps:-
Full load:-
I doubt the power circuits on this AM2 board will cope with 4 cores.
TT Big Typhoon on CPU, and 3 120mm fans on the case providing case cooling.
Jokester
Nice and toasty there:)
What chips that?
My poor NB fan is working overtime at the moment, I really need to get a decent one. I've set mine to come on full at 45C, so now its spinning full pelt all the time. Anyone know of any decent NB coolers that will fit under an X1800? Would like that Jing Ting one but can't seem to source one..
Cpu 43 (amd 4000+ clawhammer 939)
which is very good considering the summer (all due to my messing withe the blowhole on the top of my wavemaster so it blows inwards and gives me a intake which works
Ambient temperature 45 (according to graphics card sensor)
Gpu 43 (fitted with arctic cooling 5 rev 2) (x850xtpe)
mobo 35
Fans
Intake
2x80mm and front (as good as blocked out, bad case design)
1x80mm and top, probly moves as much as the 2 at the front
Outake
Graphics card cooler
2x80mm on psu
1x80mm on rear of case
Idle temps:-
http://premium1.uploadit.org/jokester//idletemp.JPG[/IMG
Full load:-
[IMG]http://premium1.uploadit.org/jokester//fullloadtemp.JPG
Jokester
127c :eek:
CPU: 42c
System Tempt: 32c (what is this exactly? Motherboard?)
GPU: 59c (Slightly overclocked)
Hard Drive: 41c
Not too bad considering my room is boiling.
ATM:
Temperatures:
Motherboard 37 °C (99 °F)
CPU 38 °C (100 °F)
GPU 48 °C (118 °F)
GPU Ambient 38 °C (100 °F)
WDC WD1200JS-00MHB0 38 °C (100 °F)
in a Super Lanboy :cool:
wow just ran speed fan and my chipset is -128, pretty good on air cooling no?
anyway
cpu = 38
chipset = 38
gpu = 47
hdd = 33
hdd2 = 31
Fans
3x akasa 120mm blue LED
1x akasa 80mm blue LED
1x thermaltake thunderblade( you guessed it, blue LED)
1x 120mm blue led (power supply)
Temperatures
Motherboard 38 °C (100 °F)
CPU 48 °C (118 °F)
Aux 47 °C (117 °F)
GPU 51 °C (124 °F)
GPU Ambient 45 °C (113 °F)
Maxtor 6B200M0 35 °C (95 °F)
That's all stock fans, a front fan blowing onto the HDD and 2 exhaust fans.
Room temp. is around 29 degrees.
CPU - 31
Case - 33
"Temp 3" (no idea what that is) - 35
HD0 - 33
HD1 - 35
GPU - 50 (with overdrive enabled)
Akasa Amber 120mm intake/CPU and exhaust all at lowest RPM.
Not sure what temp the room is, all I know is I'm warm :)
CPU: 39ºC
System: 38ºC
According to my motherboard monitor, on an AMD Athon x64 3000+ skt 754 at 2.4Ghz stable air cooled with an Akasa cooler.
This is what SpeedFan says...
I've labled the parts that I know what they are, the CPU and System, the other temps I don't know what they are.
All temps are on idling.
CPU 37C
GPU 42C
GPU Ambient 37C
Maxtor 80GB 28C
I didnt know your temps could be below your room temp at any point with air cooling....
