Temperatures... how hot is yours?
lol :D im doing an in-depth virus scan atm. cpu 45, southbridge 42c. dont know what the case temp is, it isnt measured.
oh, 3ghz opteron on air btw
These are my temps with my cpu at 2.8 and both my graphic cards at 490/1300
CPU 31 °C (88 °F)
Chipset 48 °C (118 °F)
GPU1: GPU 34 °C (93 °F)
GPU2: GPU 39 °C (102 °F)
Case 34 degrees
CPU 44 @ full load on both cores (overclocked X2).
I guess I have the Ninja's huge 120mm fan to thank for that :cool:
Athlon XP 3000+ w/ Si97 - 42 degrees
Motherboard - 25 degrees
6800GT w/ VF700 @ 7v - 60 degrees
No idea what room temperature is
My X2 3800 has got that hot it's started getting unstable.. had to back off down to 2.2Ghz and reduce the load F@H was putting on it.
It was peaking at over 55degC.. I need a new cooler - lol
39c full load processor temp (According to speedfan)
35c case temp
41c hdd 0
36c hdd 1
3500+ Venice @ 2617MHz
3700SD at 2.6 1.55V, 7800gtx at 516/1.37
CPU 36 with Apex Ultra fans at minimum
Mobo 32
Chipset 38
OS HDD 34
Progs HDD 26
GPU 35 on Water
AM2 3800 - 64 C
7950 - 75 C
Inside the Case - 36 C
Them are the max's, they are so hot.. the psu fan blows out so much hot air it makes this room like a suana.
Room temp is rediculously hot at 28c ATM, but comp is idle
fx60 @ 2.8, with a flower, at 39c
my x1900xts, with vf900's, at 39c
HD's at 32c
using a pretty cheap FSP 700w, Enermax CS-527, and using 3 80mm ambers at 12v and a 120mm amber at the front at 12v
all of it is rediculously loud, but better than when I had stock coolers...
A64 3500+ OC'ed to 2.65ghz with 1.575v is
CPU: 48 idle and went up to 62 when playing CSS
GPU: 52
Case: 34
GPU Ambient: 45
Room temperature: 27.98 degrees
Everything is a good 10 degs up from normal!
X2 3800 Teledo @ Stock :eek:
Room temp is 22c
x2 @ 2.75 1.6v - 35c idle 40c load (f@h)
x1900 - 39 idle 41 load
x1900 vrm - 59 - 63 load
chipset (nf4) - 49 - passive
pwm - 55 load
p-d 930 @ 4.5ghz - 30c idle 45c load
pwm 40c idle 70c load
7600gt 32c idle 37 load
mobo 32c idle 35 load
2 fans on 120.2 at 5v and psu fan are all i have on in both rigs so my room would be quiet if it wasnt for aircon.
the crunchers for f@h in my bathroom, are ****ing hot due to no airflow in that room :eek:
Interesting reading through this thread. Anyways..
Pentium D 805 Smithfield @ 4.0Ghz here
IDLE/Windows Tasks - 44c with Radiator fan at 2400RPM
IDLE/Windows Tasks - 49C with Radiator Fan at 900RPM
Games/Heavy Loads - 63C with Radiator Fan at 2400RPM
DUAL Prime95 Load - 69C with Radiator Fan at 2400RPM
Playing Fear this morning didn't peak it above 62C.
CPU doesn't throttle/become unstable until it reaches 74C, and my Vcore must be an all time low of 1.375 for this chip at this speed :D :D :D
Read it an weep boys, lol ;)
