Temperatures... how hot is yours?
Swapped out the 3700+ being cooled by an Arctic Freezer 64 for a 3500+ @ 2500Mhz being cooled by a lapped to 600 grit Arctic Freezer 64 Pro and idle temps have dropped to 39 degrees. The TDP of the chips is 62W v 38W. This week I am going to have an OCing shootout between the two. Might throw my little 3000+ in there too.
3000+ 1.5v 2.6Ghz at 36'C
7900GT 1.4Vcore 2.3Vmem 42'C
WD 74Gb Raptor 38'C
Seagate 160Gb 36'C
Water temp 33'C
Case temp 31'C
Ambient 28'C (tis hot :( )
1 Akasa blue 120 fan cooling PSU (drawing air out of custom hole in top of case :) )
1 Akasa blue 120 fan in side window blowing over Ramsinks on GFX
2 Akasa 120 fans on 120.1 Rad (push/pull) attached to intake at front of case
1 Akasa blue 120 fan exhaust at rear
All waterblocks and the chipset cooler lapped to 1500 Grade emery
All in a (heavily modified) Akasa Eclipse-62
it's slightly louder that i would like... but tis nice and cool, even in this weather, and the Green UV-ed water plus all the blue fans looks awesome :)
This is the highest iv'e seen my rig on idle:
Right now its, CPU 41C
Case 35C
Motherboard 34C
Harddrive 55C
Ambient temp is 32C! WOOT :cool:
Have one intake 12cm, one exhaust 12cm, one side fan 8cm, two on PSU, and a GOrbII
room temp 30c
case - akasa eclipse
mobo - abit nf7-s 2.0
gpu -Aopen 6800gt agp (fans controlled by EXPERTool 50%-2d 75%-3d)
cpu - amd xp barton 2800 @ 1.65v 3200
mem - corsair 2x512mb 3200 2-3-3-11
case/system 38c
cpu idle 48.5c @3000rpm - silent
cpu load 51c @3500rpm - slightly audible
gpu idle 61c
gpu load 75c
northbridge - zalman passive nbj? (copper "looking" hs) AS epoxy/AS3 mix.
cpu hsf - TT Volcano12 3000-6000rpm AS5
case fans - 2x akasa amber 1in 1out (rattling and on last legs), about to fit 2x scythe s-flex 1600rpm
very stable :D
