- 24 Sep 2007
As a cheap solution, you could:
Put a laminated sign on the bin saying this bin is solely for use of flat X.
Buy some gorilla tape, then after you have used the bin, add 2 - 4 strips of gorilla tape to tape down bin lid. You will have to remove this tape before you put the bin out. However, it will help convey the message not to use your bin, and it is an inconvenience for anyone attempting to use it.
