Independent riding...
Don't worry if you take a wrong turn just find a way to the area you were asked to head towards.
I was told by a mate of mine who instructs that they will shout at you on purpose "WHAT ARE YOU DOING???" simply to put more pressure on you to see how you take it. So if you feel as though you are making their life hell. You are not, they are actually trying to make you a better rider!
Mod 1 is the toughest and even that isn't TBH, just the U Turn, one foot down and you're toast. Plus, don't forget, technically it's THREE U Turns as you have to get ready for hazard avoidance and the emergency stop... they WILL fail you for touching ground on any of the three. however you don't have to do the 2nd and 3rd turns in the white lines, you have loads of room so, use it...
Mod 2, is straight forward, just always life saver, keep to the right on right hand turns, left on left hand turns so there's not enough room for other bikers to slip in... indicate and try and turn them off... can't think of anything else, just stay calm.
What so you get to take the uturns multiple times or is it a flat foot down instant fail of the entire test?
How much previous bike experience do you have already?
20 hours riding and you should pass with flying colours!
Do you drive a car?
I did 10 hours lessons then DAS which was around another 10 hours and flew through my tests and thats with no road experience![]()
2 Minors... both on the way back to the centre, 1 for following a car off a round about at about 1.5 seconds instead of 4 (it was wettish conditions) and 1 for doing 32 in a 60 after a round about. If there was any traffic Id have failed for the second one
