Above sound familiar at all? don't even know where to start with this one...
-Went from a 3070 (FHR)+r5 3060
to
(updated mobo bios)
-3080ti fe +r7 5800x
-Installed crucial p5 ssd (nvme)
to
-3070ti fe.
Something has happened in that upgrade path, as now I've been getting horrible texture pop ins, draw distances and shadow glitches across multiple games (below). All 6 games tested have glitches.
I only played horizon on the 3080ti for 30+ hrs, and only noticed the odd bit of bad texture pop once or twice. Now I find it every 10mins. Could 3070ti be bad?
**edit also rarely get a massive fps drop in horizon. 60fps constant drops to like 25-35 for 3 secs then back to normal. Happens every hour or so.
Details:
Poor draw distances and texture pop in whilst moving ...
-Horizon zero dawn : individual bush's, textures on rocks like moss and snow patterns pop in/out in some areas, grass AA looks very fuzzy and also grass is very thinly built after about 20-30 metres, at the point where its detail draws/pops in).
-Mechwarrior 5: about 5% of the ground rocks pop in at 20-30 metres also.
-Comanche: basically every tree pops into view at around 400metres.
Shakey low fps like mini map/compass in...
-All 3 games with mini-map/compass
(was the same on 3080ti in horizon),+ Comanche, Mech 5.
Flashing Shadows...
-Commanche: REALLY bad shadows, almost all of them constantly pop in and out whilst moving, some shimmer without moving, tree shadows constantly flash.
-Horizon: shadows around the stalactites (could be textures) are a very odd colour and pop in and out of normal/blue at around 5 metres in one cave.
-Man Eater: some shadows (not all shimmer as they move and are very made of massive pixels.
Potential issues...
(yes, **worst build I've done
-spilt a bit of kyronaut paste into cpu socket but thought cleaned up nicely.
-I did have to YANK a 3080ti out of the pcie socket (snapping the retention clip of mobo). There was some bending on the mobo and also dropped a screwdriver on mobo trying to open clip.
Also...
-something hot in pc (46-53c idle), mobo fan idles around 2000rpm and often goes up to +3000rpm.
**what I've tried so far as of 12/11/2021**
-RE-installing newest 3070ti drivers in safe mode after using DDU.
-tried 10+ games across different SSD's. All inhibit some issues.
-"trc" changed "bank cycle time" from 75 to 58 as per jdec specs (all others to xmp).
-tried 3070ti in both pcie slots.
-updated chipset drivers (I was on stock).
-replaced with a gigabyte 3080.
-loaded optimised defaults in BIOS, note: left ram on stock from here.
-fiddled with most display settings in nvidia control panel.
Then...
-disconnected everything (USB 3.0, sound card, all fans ALL old SSD's), left memory in as can't access easy.
-fresh copy of Windows 10, on a brand new ssd.
-did win10 updates,
-installed newest gpu driver (ddu+safe mode).
-loaded Horizon, still looks bad.
-Tried last know working gpu driver (same one I would have used on rtx3070 (June 2021) using DDU + safe mode.
-tried all psu cables in different ports.
-different sata and pcie power cables.
-tried powering pc from different wall socket, room, and also a mains filtering extension.
-plugged gpu into a work monitor with DisplayPort (instead of usual hdmi).
-cleared CMOS.
-48 passes (all) of memtest (default clocks)
-tried praying to the PC gods....
Next steps?
-Try ram in diff slots.
-Try 3080 and ram in new system when it arrives(3700x, a used replacement x570-p, seasonic 850w and the ssd I got before).
-Re-inspect cpu/socket for excess TIM.
Specs...
R7 5800x
Asus x570-p
32gb Vengeance 3200mhz
Evga p2 850w
TV - Panasonic 120hz 4k hdr TV
Any ideas guys? Is it likely hardware or software?
to
(updated mobo bios)
to
-3070ti fe.
Details:
Flashing Shadows...
Potential issues...
)-spilt a bit of kyronaut paste into cpu socket but thought cleaned up nicely.
Also...
Then...
-did win10 updates,
-cleared CMOS.
Next steps?
Specs...
R7 5800x
Asus x570-p
Evga p2 850w
