TF2 problem
1 Mar 2007
Portsmouth
Brought the orange box, and Iam trying to play TF2. Loads up past the valve logo, then stutters abit. Start a game then my pc will crash and monitor will enter power save mode.
Anyone know why Iam having this problem? Iam running x64 vista, originally thought it might be because off dreamscence running that, but ive disabled it and still having the same problem.
I had a similar problem a little while ago, albeit on a different system, however you could try this:
Open up Steam
Browse to the game (in this case TF2) in the "My Games" panel
Right click on the game name and select "Properties"
In the "General" tab press the "Set launch options..." button.
In the new window type "-dxlevel 90" without the ""
Try and launch the game
If that fails try it with DX levels 81, 80 and 70
This sets the DX version the game uses to load, it worked for me. The problem I had is that you must re-set the graphical settings you use each time the game starts, obviously this is far from ideal, but it may be worth a shot to try at least. For some reason it eventually started to work normally, no idea why, may do the same for you.
- Pea0n
Cheers Pea0n, tried setting it at -dxlevel 90. Launched the game no stuttering, found a server started to play for about a min then it crashed and monitor went off. Had to switch off the pc on both times as the reset didnt work.
Oh well mate was worth a shot :(
- Pea0n
