Pretty much identical to the swift, but you get freesync over gsync - in what way does it make this 'superior' over the swift ?
Are people really comparing Asus ROG prices against the likes of BenQ prices?
It's £130 cheaper for a start and I haven't read into it yet but shanks said something about freesync offering framerate control over gsync.
One simple Setting! Freedom over your Frame rate.. FreeSync offer best of both worlds..
Looking forward to reading some user reviews!![]()
If the stock lands today, with you tomorrow, if it arrives tomorrow then with you Wednesday.![]()
That makes this panel superior over the Swift due to that ? More features, slight upgrade, maybe even use 'better' at a push, but superior ? Buzz word for a sale me thinks.
Until we see a similar gsync monitor with the same kind of spec then there's not much else to compare it to.
It's practically the same panel used. Cheaper that's a given, we know that. A feature of Freesync over Gysnc means its superior ? Maybe I'm in the wrong game then. My Golf is superior to a Bugatti Veyron, it does more MPG.
Does this use the same panel as the swift?
Look, there's the AMD fanboys arriving.![]()
True I suppose, hence I suspect this has the same au optronics panel as the swift. Au being owned by benq.I dont think there is more than one TN 1440p 144Hz panel being used at present ?
