The Great Thermal Interface Material Con
The final results are in!
First up AS5:-
Load 48 (and maybe pushing 49)
Chipset 32
Next up, the new challenger for the crown, Coollaboratory Liquid Pro:-
Load 47
Chipset 32
Liquid Pro pips AS5 to the post, despite being ever so slightly warmer (chipset reached 32C a lot quicker) it held load temp at least 1 (!) C cooler than the AS5.
As regards the curing of AS5, I'm not overly convinced of the gains that can supposedly be had as I've seen little to back it up.
Jokester
What is it exactly... just a metal thats liquid at room temperature like mercury?
thats stupid since solids are naturally better conductors of heat than liquids, i tried my CNPS9500 without any TIM and it worked fine, 2*C below what i was getting using ceramique, was as close to perfectly flat as one can get (no lapping, came that way) so contact was very good :) give it a try sometime, remember solids are better conductors than liquids so copper is gonna conduct heat quicker and more efficiently than some layer of goop and then copper
But AIR is a lousy conductor of heat. The whole point of the thermal compound is to allow metal to metal contact where possible, BUT to make sure any minute air pockets are avoided, and are instead filled with the compound as the 'next best thing' to metal > metal contact.
Solids do conduct heat better then liquids... at least stationary ones.
AS5 is a suspension though... mostly liquid with disolved or suspended mettalic particles. Not suprising that a 100% liquid metal in between would give better conduction.
Running without any TIM and getting better results is either down to their being some residule TIM on one of the contact surfaces or there being too thick a layer of TIM when testing with that, or both. It is possible you have very finely polished surfaces, but it should still benefit from a little TIM.
According to my good friend wikipedia, after testing some liquid silver alloy we should get to work on tracking down some liquid diamond paste :D http://en.wikipedia.org/wiki/Thermal_conductance#Examples
Im wondering though... considering that the chip being tested has an integrated heatspreader...
Im betting that the direct contact heatsink test would be different if it werent for that rough heat spreader... but you would neet a little toothpaste to get contact to all the chip.
Seriously though, the toothpaste is partially evaporating as the test is going, so your actually using a phase change cooling system vs air cooling. I know toothpaste burns, and burns at a pretty low temperature so i would be carefull with any tests over an hour at over 50 C
*Update*
Took the waterblock off my CPU and the Liquid Pro had dried out and welded itself to the both surfaces in an uneven distribution. Took 20mins of elbow grease and Brasso to get the worst of it off before reapplying it again.
Jokester
Jokester said:
*Update*
Jokester
Ouch :(
