The New Lian case. Li PC-7 SE-B II
8 Nov 2003
england
Hi guys
was wondering if theres anyone out there with the new Lian Li PC-7 SE-B II case .i am thinking about buying it but would like to hear from others who might have it. this is what it looks like
my pc7+ came with thumb screws?
isnt that fan attachment thing just the BS01 ?
I guess they don't want to mess with a winning design too much
^^ So is the one on ocuk the version that can house 2x 120mm fans intake exhaust, coz it dont say in the description?
dont think so .on the other site its on pre order so it must be very new.
The Lian PC 7 SE II housing represents again improved, particularly for PC-Cooling manufactured a variant to successful PC 7 of model.
In the “Special edition II” the housing ventilation was continued to optimize. Three 3.5” drive assemblies (HDD) can internal be installed. The housing is completely from aluminum manufactured and thus extremely easily - due to its conception in particular for Overclockingzwecke or however the employment with Lan Parties very well suitable. The integrated ventilation system makes a clear sinking for the interior temperature possible of the housing. The material aluminum contributes likewise to an improved heat dissipation. Altogether nine drive assemblies can be inserted (4 x 5.25” and 2 x 3.5” externally, as well as 3 x 3.5” internally).
The scope of supply contains three transparent 120 x 120 x 25 mm of Cooltek Ultra silent exhaust (17 dBa, 1,000 rpm):
# An exhaust provides within the lower housing range for cooling and the Einströmem of refreshing fresh air - air is led directly over the non removable disks. Air flowing in is led by a filter cartridge. The filter cartridge can be removed for the cleaning.
# Second 120 mm the exhaust sucks off warmed up air at the back.
# Again more appropriate and parallel to the Main board a more adjustably 120 mm of exhausts is laterally over the PCI Slots, which serves for the direct warm air removal of the blocked plug-in cards. Current diagram map radiators can be effectively supported in such a way in their cooling performance.
All three exhausts are provided with an exhaust lattice and have a 3-poligen Molexstecker.
In the frame cover is a ventilator opening, to which further 80 mm an exhaust (screwing assembly) can be installed.
The side panels are fastened with Thumbscrews - the front screen is attached to the chassis (art off tie-clips). The drive assembly covers consist likewise of aluminum.
In the lower housing front are connection types for:
- 2 x USB haven (2.0)
- 2 x connection for sound (Micro, Headphone)
- 1 x Firewire
Appropriate components can be attached so simply and comfortably from the front.
Guys OcUK have had this for 12 months, for £15 less. :confused:
Lian Li PC7+, same box as the PC7+II.
Just this has the new side panel, which OcUK HAVE been shipping out as people have posted about it.
Nothing new I assure you, OcUK miles cheaper and have had it for a lot longer. :confused:
The Photo's on OcUK are NOT representative of the actual product. You do need to read the small print.
The big difference with the new one is that it has the same insides as the V600 and the G50 so it has tool-less HDD mounts and the side mounted 120mm extraction fan. That fan is not the blower fan from the PC-65/V1000, it's a straight 120mm.
I'm not sure if this is the OcUK one or not as I didn't think they were out yet officially, although more grey import Lian Li seems to come into the UK than the official stuff.
I bought the PC7 from OcUK about 2-3 months ago, I recieved the case with 2x120mm fans, one front, one rear and the new sidepannel with the 'mesh' over the graphics card area. All you need to do is buy the PC7 from OcUK and get the BS01 and it's exactly the same as 'the new pc7'. :rolleyes:
I would upload some pictures but my bluetooth is being stupid.
InvG
but the ones they have now are new stock. so i dont think there the same they had a few months back
The case will be the same, OcUK will get the latest revisions of the case, and it's doubtful that Lian-Li would ship the PC with the extra cooler.
By the looks of things the cooler shown in the above picture is infact a revision of the BS01 cooler.
Don't quote me on that though.
-=EDIT=-
Some pictures of my case to illustrate what I mean...
The case,
The side,
The window/mesh,
InvG
I've had my case 3 weeks mate and its got the 120mm on intake and exhaust and the modified sidepanel. (I've bought a windowed side panel anyway).
Has the thumb screws and all that jazz.
On another note, i'm not asking for links or anything ,but are there places that sell the Lian-li accessories? For instance the BS01, rear ducts etc etc
The small print says
Dimension: 210x450x490 mm ( W,H,D)
- Drive bays 4x5.25", 2x3.5", 3x3.5" internal
- Fan: 12 cm ball bearing x 1, 8 cm sleeve fan x 1
- M/B type: ATX & pentium 4 (max size: 12"x9.6")
- PSU Type:ATX
- USB2.0 x 2 IEEE 1394 x 1MIC x 1EAR x 1
so to me it looks like it has a 12cm fan on the front and only a 8cm fan on the back or is a sleeve fan the one on the side of the case ?
It's because officially OcUK's listing is for the PC7 with the 12 and 80, but Lian-Li seem to only be shipping them the 120 + 120 versions.
InvG
