2. RESTRICTIONS
You may not lease, rent, sublicense, publish, modify, adapt, or translate any portion of the System Software. To the fullest extent permitted by law, you may not reverse engineer, decompile, or disassemble any portion of the System Software, or create any derivative works, or otherwise attempt to create System Software source code from its object code. You may not (i) use any unauthorized, illegal, counterfeit, or modified hardware or software in connection with the System Software, including use of tools to bypass, disable, or circumvent any encryption, security, or authentication mechanism for the PSP™ system; (ii) violate any laws, regulations or statutes, or rights of SCE or third parties in connection with your access to or use of the System Software, including the access, use, or distribution of any software or hardware that you know or should have known to be infringing or pirated; (iii) use any hardware or software to cause the System Software to accept or use unauthorized, illegal, or pirated software or hardware; (iv) obtain the System Software in any manner other than through SCE's authorized distribution methods; or (v) exploit the System Software in any manner other than to use it in your PSP™ system in accordance with the accompanying documentation and with authorized software or hardware, including use of the System Software to design, develop, update, or distribute unauthorized software or hardware for use in connection with the PSP™ system for any reason. Any violation of these restrictions may void the PSP™ system's warranty and affect your ability to obtain warranty services and repair services from SCE or its affiliated companies.
PSP™ System Software may contain technology that is subject to export control laws and regulations of the United States, including but not limited to the Export Administration Regulations and the embargo and sanctions regimes of the U.S. Department of Treasury, Office of Foreign Asset Controls. As such, the PSP™ system may not be exported or re-exported to persons and entities prohibited by such laws and regulations.
