The phone obviously does still work on 2G and 3G networks as well. You just can't manually force 3G. This is the extent of the options screen
I'm not sure how many people would care about this but there are places I'll get 1 bar on 4G but full signal on 3G. Because the phone prefers to use 4G it'll hold onto the crappy 4G signal instead of dropping to the solid 3G signal so it's a bit annoying that I can now no longer force it.
Weird. I'd try removing it then reinstalling it, but it's a strange one for sure.
In the App Store tap your user icon in the top right corner and it'll bring up account info. You can pull down on that screen to check for updates. Mine wasn't showing anything since I'd set everything up fresh but just now two app updates have appeared there.
Apps have always auto-updated for me.Do Apps auto update still? my ipad has not auto updated apps in ages, always have to do it manually.
I thought for a minute that 3G would not work at all. I’m an ex android user and think on my last galaxy you could force 3G. I’m led to believe on iOS that option hasn’t been there since maybe iOS 12?
Upcoming automatic updates should appear under personalised recommendations and above sign out.
Already tried mateI'd recommend signing out and signing back in.
Already tried mate
If you hold down on the app store icon there's an option to check for updates. I assume that doesn't return anything?
Yes you'll get borders at the edge in Netflix on the 12 Pro. I'm sure the same applies to the Pro Max too as the aspect ratios are all the same.
I'd disagree that there's not a lot of difference in size between 12 Pro and 12 Pro Max though. It may not look like it's all that much but it'll certainly be noticeable in the hand. I had an 11 Pro Max before and took the chance to drop to the 12 Pro as I found the 11 Pro Max too big and too heavy. The 12 Pro works so much better for me and the 12 Pro Max is even bigger than my 11 Pro Max was. However it's all subjective, but the difference between 12 Pro and 12 Pro Max is 6.6mm in width and 14.1mm in height, I think it'll feel a lot more substantial than you'd think. The comparison images certainly seem to make it look hefty.
The back is gorgeous. The sides are hideous. The tackiest shiniest blue fingerprint nasty magnet.Anyone get the 12 pro in blue? I’m waiting for the max and not sure if I should get the blue or not.
