^ The Surge ^
I've played it for a bit and defeated around 4 bosses. If you played Dark souls or Bloodborne then you will like it. The nice thing about it is the way you get new gear, you can target specific parts of enemies and when you hit them enough on that (body) part then you can rip it off and get that equipment.
Enemies overall are decent, and level design in terms of unlocking shortcuts are good too. The kill animations are also very well done.
Only downside from what I have seen is that you won't be able to make crazy builds at end game you will be stuck with a set of builds based on armor type and weapons.
