Hi Guys
Yesterday we launched a new line of thermal materials which is looking set to be the go to product for hardware & overclocking enthusiasts.
Thermal Grizzly has been reported to give serious advantages in temperature drops using ambient cooling as well as holding up best in extreme circumstances like sub zero cooling.
8Pack has been raving in the office about this stuff for months and we now finally have it available for retail.
Thermal Grizzly tubes come with an applicator which allows for a nice even spread of paste on the IHS too which makes it easy to apply.
The paste comes in three varieties:
Aeronaut is a high performance material designed for application with air coolers or as a replacement for stock TIM that comes pre installed on hardware. Aeronaut has strong thermal conductivity and is perfect for end users looking to optimise their air cooling.
Hydronaut provides excellent thermal conductivity and is designed primarily for watercooling. It should also be considered by users looking to get the most out of very large heatsinks too. Hydronaut is incredibly easy to apply
Kryonaut is the ultimate performance thermal compound from Thermal Grizzly and offers superior performance in extreme or high demand applications. Kyronaut has the best long term stability out of the whole range and proves to be excellent in every single application.
Minus Pad is a thermal pad with a high level of elasticity that uses a ceramic silicon formula to provide superior thermal conductivity over other pads. These are ideal to replace stock pads on VGA air and water coolers but can also be used at -100°C
Overclockers UK is the proud retailer for Thermal Grizzly and we hope that you guys will all be keen to try it out with your next system.
To view the full range, click the banner below:
