Thermaltake Mozart TX
Might be a bit of a squeeze but you might be able to fit this in there Dubs. ;)
I take the kids up there all the time :) it's pretty tidy now :)
Me, the missus and the kids took a walk up the side of that water feature with two pushchairs... Never again LOL that is WAY steeper than it looks isn't it hehe
You've gone and started me thinking now....There's enough room in the Mozart for a cascade watercooler sytem...Mmmmm
So how far did you get ideas wise?
I have 6 copper lined 150x400 aluminum radient panel sitting here unused.
that's 360,000mm2 of radient cooling that isn't affected by ambient temps.
With a further 500,000 (0.5 m2) of convective cooling surface area on the reverse side.
Edit: Like the Konvekt-O-Matic MAXI-plus design
much better that the old finned tubes design of the Maxi/ultra/cape corra stuff
To compare a thermalright silver arrow has 5,150mm2 of surface area,
but this works as an assisted convective cooling which is more efficient.
But I could only get 3 sets of custom brass barbs for them before the company went belly up :(
A laith could make some more, or you could just weld on some normal G3/8
barbs to the panels (G1/4 would be to small).
If you go down this route let me know and I'm sure I can lug them to the post office for you at cost.
had 2 of these, they were awesome!
Locky did you buy mine? I had one of them with akasa matting
i think artheos bought my other one, he powder coated it black in and out
naaaa that was me dude, i swapped one with you for something ( cant remember what now ) and had it powder coated.
I still use it.. best case ive had. Super quiet and super cool and i fitted wheels! :p
Cheers for the info Shadow, and thanks also for the e-mail. i've been following your fanless build and admire your work, particularly your inovation skills. Not sure yet if i'll use the panels, but both they and your build have given me lots of spin off ideas.
Case is now on its way to me in the post, which is much better than having to go and collect it. I worked out it would cost £40 in fuel, and the chap has posted it Parselforce 48 hour for £12.99.
Should be here Monday.
I'm like a kid waiting for Santa to come at the moment!!!
Monday is here and so is the case.
WoooooHoooo
first time I've seen it in the flesh and have to say I'm very impressed with it. The guy I bought it from has looked after it well and it came packaged well so no marks at all.
it's big, and I mean BIG.
I'll try to get some pictures up in next few days.
Currently have it sitting on the side in my room. It's going to take me a little while just looking at it and visualising what I'm going to do. Also will be taking it apart to see how it's put together and see what is feasible with it.
Things decided so far:
Custom paint job inside and out
Modding the windows and doors. removing rivets and replacing with allen head bolts. replacing widow with either smoked or 1 way mirror.
i7 9 series processor, monster graphics, SSD etc.
And finally the reason I went for this case in the first place....
Triple loop water-cooling (3 rads 3 pumps 3 reservoirs)
Over kill I know but I have the water-cooling bug big time and it's and itch I just gotta scratch.
