I just ordered one from this website. I use an overclocked AMD 1100T BE at 3.8GHz (up from 3.3) with an Arctic Cooling Freezer 7 Rev.2 cooler and its just not doing the business. Checking core Temp after a game, says my temps while in game were running at 69 degrees c.
(I hear that's not so good. Luckily I haven't had any problems with BSOD or whatever I just decided to get a better cooler.)
So I was thinking about getting the Corsair H80 First, Then it was the Thermaltake Frio, Then it was the Noctua D14
Anyway I saw the reviews regarding the sound on the H80, (too loud, i wanted something quiet.) - The reviews on the D14 (too ugly and too big for me.)
And finally the Thermaltake Frio (Seemed too cheapy and similar to my old cooler).
So I finally decided on the Silver Arrow because i like the way it looks and it benched slightly better than the D14. which is good! (But I didn't realise it was A BIG as the D14!) I was going for future proof performance when i ordered the cooler, that was the plan anyway.
So I am also wondering, How is the Silver Arrow IRL? and it does come with the 2x 140mm Fans included right? Link here: https://www.overclockers.co.uk/showproduct.php?prodid=HS-078-TR
And will it fit inside a Fractal Designs R3 case? Apparently the D14 will, I read somewhere so I am hoping this will as well...
Thanks all!
Thanks all!
