your spec with toothpaste is getting better temps than my old spec with AS5!
Historically speaking Toothpaste always beat AS in the tests, however it lasts about as long as a pack of Jaffa cakes in the break room
1) where did you get your data from?
quick steel works better then copper slipHaha this is brilliant!
Have to say I'd have probably gone with the copper grease before toothpaste!
Slightly more modern review of thermal compound including toothpaste:
http://www.hardwaresecrets.com/printpage/Thermal-Compound-Roundup-July-2011/1334
Looks like toothpaste starts out OK, but a 3 degree increase in only 12 hours is pretty scary if that continues degrading at that rate!
