Couldnt help but think that they've turned off
Let it go many it's been 3 years!
No-one else thinking the Lexus is basicly the new Supra?
Loved the episode
Couldnt help but think that they've turned off everything in the X6 than just stuck it on some loose ground and nailed the throttle to make the point that its not as good as the rangerover
Adjustable height control - not needed to go up a slight grassy slope. Hill descent control - again not needed to go up a grassy hill. Locking differential, again not needed to up a grassy hill iirc ?
I bet the X6 is far better on snow and grass than they made out, but again turned everything off to make the point in an easy to understand way for the viewers.
would the rangerover have breezed up the hill the way it did on summer tyres too though ?
Anybody watch the Bolivia special? I thought it was a fantastic episode.
how is the engine not seizing at those angles?über descent vid
Loved the episode
we know that the Rangerover and the Disco are very good offroad, but it all depends on the spec
As already posted ive heard stories of range rover sports doing exactly the same as the X6 given the slightest snowly incline, so i was a bit skeptical to see the RR breeze up the hill and the X6 languish there.
well yes, obviously it's because they are designed to go off road.Because Land Rovers are designed to go off road. I doubt BMW were quite so thorough with the X6.
