Yay
We got there in the end.
I was referring to you in light of your behaviour plus my experiences with other building surveyors.
Yay
Grenfell Tower: Cladding 'changed to cheaper version'
Quoting this one for truth. They're horrendous.Its not as black and white for me as to whether the regs are right or wrong and/or if peoples interpretation of them is incorrect. Industry has said for years that the Building Regulations need an overhaul, they are out of date, unclear and clauses refer to clauses which in turn refer to clauses which then refer you to an external BS document. Its no wonder people get things wrong.
http://www.bbc.co.uk/news/uk-40453054
Tory austerity is to blame then, that and the tory run council.
if you read the article you'd aee the zinc was more retardant than aluminium
Earlier planning documents suggest the original plan was for zinc cladding with a fire-retardant core.
Does it?
The core of both will have been the same, the skin of the cladding is not fire retardant.
If it turns out the insulation in the original spec cladding was fire resistant then whoever made that change will be in big trouble (unless they can prove the contractors were asked to ensure the new cladding met the same standards as the original spec ofc).
Residents had also been told their new cladding would be made of zinc. Despite their differences, both types of cladding have the same official fire rating.
People are going to get hung up on value engineering (I hate that term, it turns my stomach) but theres only one reason you go from zinc to aluminium. That BBC article does say;
This investigation is going to be very frustrating for some people I think because they are going to interpret what is very standard industry practice as either error or malicious intent. Its also not going to look to deeply into certain areas either and I think that will annoy people.
I'll put my money where my mouth is though and say no one will be prosecuted on this because its not a failing in one area, its been a bit of perfect storm scenario.
This investigation will give them none of the above and I can pretty much see a lot of the public taking matters into their own hands.
The regulations if not explicit will have been loose enough to become open to interpretation, which cannot then be chalked up as being a malicious intent to kill residents. Moreover it would be just as difficult to open it up and say it was incompetence because technically the regs were adhered to as materials that were BS accredited and met the requirements were allegedly used.
The regulations are actually quite explicit, the cladding used on Grenfell should not have been used. The question it comes down too is, did the person who selected the cladding know it didn't comply with the regulations and use it anyway to reduce costs, or did they make an honest mistake. The issue there is how could you ever prove the former without them admitting it, and in the case of the latter where do you go from there, granted if their mistake cost lives there is an argument of negligence but if it is a mistake that a "reasonable man" would be likely to make given the information available then that usually protects people from negligence. As far as that goes the data sheet for the product does give the impression it has good fire protection values when this is completely untrue but that is because it highlights the products pros and not it's cons which is normal for almost any product, though having said that you would have expected them to want buyers to know that the more expensive FR boards are better protected against fire than the PE boards, but I guess not lol.
Like LOAM said, perfect storm.
