Because his opening post was pretty much "I know this is illegal and dangerous but do you think I can get away with it?"
What are the potential issues?
I would hazzard a guess you were not towing said big heavy cars with a Clio....
An HGV tractor circa 7.5ton can pull a lot more than the 36ish tons that would bring it to the 44t limit, the difference here is it is designed to tow much more than its own weight, an be able to brake & corner in a relatively stable manner.
You do have to be very careful in anything other than ideal conditions though.
Cars generally don't take towing much more than their own weight in their stride as they are simply not designed to do so.
The braked towing limit it there for a damn good reason, exceed it at your peril.
I'm pleased to see Mike is not going to try it (in his Clio, MG or whatever), and hope for his sake that he does not.
A lightweight 4m car trailer is around 400kg
The towing pivot is in front of the rear wheels on a tractor, on a car, the towing pivot is behind the rear wheels making it much more likely to lift them off the ground under braking.
maximum unbraked tow weight is 750kg not the 500 stated earlier in the thread.
I would pay very carfull consideration to your vehicles limits. I sell plant equipment and often sell trailers etc for smaller machines, a customer of mine had one of his workers pulled up who was about 60kg overweight he received 6 points and a £2000 fine.
Also if you passed your test after 1997 you will need to do a test to tow a braked trailer
Regards
Ross
**** me! that sounds harsh!
And you sell trailers?
I really wish people wouldn't talk silly business on the internet.
