Don’t get the fuss here, it’s a 3 cylinder Yaris with a trick drivetrain that you’re rarely going to play about with on the road. It’s also manual and mediocre on pace. They’re trading on the fascination of a “drivers car”, when in fact it’s totally outdated and will be a chore to drive on the public roads as they are nowadays.
If you want something cheap, sporty, focused as a drivers car then they already sell the GT86. It’s got the lower center of gravity, a better 4 cylinder engine, it’s just as engaging if you have to have a manual and it’s a proper RWD rather than a gimicky selectable setup. The GT looks better as well.
The hype is:
Proper 4WD drivetrain with a bespoke chassis developed for it.
Manual
Boosty 3 Pot
Light (Considering 4WD, modern crash regs)
It literally is an Impreza/EVO for the modern era. No one else is building anything like it. I was too young really to appreciate or even afford the rally cars of a past era so this is my chance.
There is no such thing as a laggy turbo these days. What you are referring too is boost threshold. Most cars have turbos that come in early but are out of breath when they reach 6k rpm. I for one would love to see more cars which have power higher up in the power band. It makes them far more fun to drive.
Also anything after the Evo 6 has no rally pedigree either as after that Mitsubishi went to the WRC standard for their cars.
Also Torsen is more than good enough for track work. Unless you are riding kerbs you are not going to be getting air in most scenario's. Locking plated diffs will obviously be better if you are doing gravel but that is not the aim for Toyota as privateer rally cars will more than likely be built by TTE anyway. There is not many cars short of exotic that offer true front and rear locking diffs on a full time AWD system either. I think the Focus RS had an option but is 400KG's heavier!
I don't disagree that modern turbos are better but having driven a lot of new cars the lack of throttle response compared to an NA is still a thing and you do still sit waiting for the boom, this has its charms in an old school way and not even noticeable when driven quickly more so on the mundane stuff when you are off boost.
As for wheels off the ground you see it all the time of little hatchbacks blimey even see the rear off the ground on my mx5 don't have to be near a kerb, I don't disagree it's a amazing package to come from a manufacturer just more of a discussion point really as someone who might buy it to use as a daily for a few years before putting it to use in club level motor sport as to whether the circuit pack makes sense.
Not had 4wd used in anger, so it may be an non issue but certainly both my cars had torsen and were great but clutched certainly better on the 5 on the hills. I guess with 4wd, even if you loose the rear you still have the front.
You have to ask permission from the ECU, it does some processing and then if it agrees, you get some throttle. There is also a limit to how fast it can open. Where as on a cable throttle you can wang it open instantly and off you go.
They can actually be quicker, in terms of response, than cable-operated systems – which sounds counter-intuitive but makes sense when you think about it; an electronic system can actually get the throttle blade open and the engine working towards producing maximum torque quicker, as you start to input a hefty accelerator pedal application, than the time taken for your foot to hit the floor in a cable-driven system and the electronics to .
A predictive advantage – it looks at what's going on, the rate of change of command inputs, and works towards meeting the upcoming demands.
Electronically controlled throttles have so many other benefits, too (which is why everything uses them these days). Most modern powertrains would drive abysmally with cable-actuated throttles, which is what I think leads to people thinking the accelerator pedal system is the issue; engines today produce so much torque, often in such an uneven fashion, and refinement requirements have gone through the roof. The net result is that the electronics have to work overboard to keep things smooth and tractable, as you suggest.
Without 'em, even in a fairly boggo hatch, it'd be easy to end up kangarooing down the road in an uncomfortable fashion and keeping everything in check would be difficult. Otherwise, when permitted, the response is just as quick – if not quicker. You don't hear people complaining about accelerator pedal response in Ferrari 458s, for example, after all; it takes no time at all for an electronically controlled throttle to go from 0 per cent to 100.
The earliest iterations could be odd, though, and there are some out there that are poorly calibrated – but the tech's been around for at least 33 years now, in production cars, so it's rarely problematic these days.
Then there are all the safety and convenience functions they enable (or allow for far easier integration of), which is why they've been effectively standard on everything for so long now.
Nothing an HKS exhaust doesn't solve, and BOV
I'm thinking the red looks amazing.
Slight bias detected.
The lack of throttle response is down to electronic throttles on many cars
Ah the fabled real enthusiasts
They generally seem to be second hand car buyers complaining that those who buy new buy the wrong cars or don't pay for the correct options
If these real enthusiasts actually put there money where there mouth was there would be far more cars that they love and far fewer for them to complain about
Its a funny world eh
