Yeah appreciate it is bespoke in many area's, still looks like a little dumpy city car
I've order before without a test drive (RS) feeling I need to try one first this time, see If I connect with it.
For sure some of the appeal is it shouldn't be as fragile as some hot hatches, Toyota reliability and warranty, with the ability to take some heavy use without issues.
I guess if you are inclined to go down the modify route, assuming limited slip diff's could be bought and fitted the base or convenience pack would make more sense. Re Litchfield already suggestion to replace the suspension on Circuit pack. There will be brake kits for sure and wheels aplenty.
The thought of a Convenience pack version did cross my mind because it will be much rarer I guess, then add the LSD as a mod.
Value wise, I think they will depreciate, 10K in 2-3 years. I'd also expect there to be plenty used for sale. As many will be bought because they are the hot choice and publicity, then people find out it's not the car for them. Similar happened with the RS, that settles down with time and values recover.
Roll on lifting of the lock down for test drives.....
