What the hell is heel/toe? This some sort of youngster speed move im not aware of![]()
Sounds like meI used to know a kid who blipped the throttle everywhere he went, whether he was changing up or down![]()
Heal and toeing is only for old beetles that die under idle quite rapidly.
You're blipping the throttle and changing down a gear, so you have to be slowing down enough to actually necessitate that next gear, or it's a bit of a wasted exercise. More than anything, I was picking up on the OP's point that he is getting resistance when trying to select a lower gear so I wanted to know if he was slowing down enough to actually warrant the lower gear.
Sounds like me
Although blipping when changing up tends to make it more jerky
I do it almost all the time when shifting down now, although I started to do it properly when I got my exhaust![]()
Equally there is probably no harm either - the syncromesh has to work less so may last longer.
Noob question but is H&T less effective or less necessary in a FI car as opposed to an NA?
H&T is good for mechanical sympathy and will save stress on engine, clutch and gearbox IF you drive on the limit, otherwise it is for track only.
A normal driver who isn't hammering his car around has no need to heel and toe, as the correct procedure is to select the correct gear in one hit and then match revs before re-engaging the clutch. Engine braking has no place in road driving anymore, barring exceptionally poor conditions that do not require H&T.
The best practice people can work on is rev-matching (upshift and downshift) as it is the biggest contributor to smooth driving on a manual car. Your passengers will thank you as it helps eliminate the see-saw motion that makes prople travel sick.
For the record, selecting the correct gear and rev matching has all the benefits of H&T in terms of mechanical sympathy, you will just be a fraction of a second slower getting the right gear for the corner.
H&T offers no benefit to a synchromesh transmission UNLESS you double clutch, as revving the engine with the clutch pressed WILL NOT spin up the mainshaft to the same speed as the layshaft.
Post makes no sense.
Engine braking has no place in road driving any more, lolwut?
Many trainees use a change of gear to reduce speed on the approach to a hazard. This is almost always a mistake, and for the purposes of part 2 should never be considered.
It is essential that you get the car to the correct speed for the hazard, then select the correct gear to match the speed.
If you plan your approach to changing speed and gear, you can rid yourself of the bad habit of 'going through the gears' every time. This is not only unnecessary, but could be dangerous, as it takes a little of your attention away from the road ahead.
There is no reason whatsoever not to get the car to the right speed, then change form 5th gear to 2nd gear, or even to 1st gear. Taking intervening gears is bad practice.
Can't really see separating downshifting and braking catching on. This is going to mean either over-revving the engine on entry, or bogging on exit. Just what is the point when both can be done smoothly simultaneously.
I guess it depends how hard you are driving - I often slow down by changing down (and rev-matching for smoothness) rather than scream up to the corner and then bang down the box. If you are not on an out and out banzai drive then you can easily not H&T but when you are driving at full attack it is obviously needed.
