trying to get steady 4ghz
21 Sep 2008
Hi guys been trying to a stable 4ghz but just cant do it it will go in to windows but once i try to do anything it restarts.
Im using these settings that might be wrong anyway
CPU CLOCK RATIO: x20
Advanced Cpu Features: all enabled with the exception of C3/c5/c7 state support.
QPI CLOCK RATIO: x36
UNCORE CLOCK: x16
Advanced Clock Control:
BCLK: 191mhz
PCI Express: 101mhz
CIA: DISABLED.
CPU CLOCK DRIVE: 800mV
PCI Ex CLOCK DRIVE: 900mV
Performance Enhance: OFF
XMP: OFF
System Memory Multi: x8
VOLTAGES:
VCORE: 1.287v
QPI: 1.215v
IOH: 1.1v
DRAM 1.5v - 1.66v
trying upping the Vcore to 1.3 & QPI to 1.335, also changed the Clock skew to 100ps, and CPU clock PLL to 1.3 instead of 1.8
@ chippy
I am running mine now, at 200 x 20, Vcore, 1.325V, QPI voltage 1.36V, CPU PLL voltage at 1.8V, and DRAM voltage at 1.64V.
RAM is set to 8x multi, with 8-8-8-24 timings.
do you get a blue screen, or does it just restart??
And yeah, this is slightly important ^^
