Yours has been pretty good though Si![]()
I still can't get over the looks of the teg, quite dated appearance and horrible headlights. Though I'm sure it's a joy to drive.
98spec JDM will fix your worrys in a second.
not for 3k though which is a shame.
Does it have to 4wd, any reason your excluding all else?
you have:
phase 1 impreza....very good cars, dont turn boost up without proper remap, people say crap engines are talking rubbish, just make sure its setup properly and it will be fine
evo 1,2,3....crankwalk issues but its overrated, dont let it put you off, good engine for up to 350bhp
pulsar gti-r...great engine, throttle bodies from factory, gearbox is the weak link, dont abuse the box and it will be fine
mazda 323 gtr.....very rare, came with all steel bottom end and roller-bearing turbo from factory...my choice
3000gt....to big and boaty, loads of electrical faults
celica st185, overall very strong, shouldnt be discounted but looks could leave a few things to be desired.
thats all i can think of at the moment
As for 4WD, the car will mainly be used in wet / snow so I want the best possible way to deal with this (without getting a pajero etc)
Most of the cars mentioned above aren't much if any better in snow than a normal fwd hatch if you're running sports summer tyres.
Very true, but I currently have a FWD hot hatch so want a change. Perhaps I shouldnt have mentioned the snow bit - its a small consideration, its not like im buying the car just for this. Plus, I want a tiny bit of practicality, i.e. a boot and so a RWD mid engined car is out of the question, as is a front engined RWD car due to terrible handling in wet (I know, I used to have one) Unless someone knows of a heavy rear weight, front engined RWD car?
RWD are not that bad in the wet, unless your an arse with on and off right foot, be progressive and you will be be surprised.
Any Impreza you buy is going to be Rebuild Imminent.
