This looks great. But is it expensive because it's so heavy duty? It's a lot more expensive than the other ones I see. Worth it?
Just checked and unpaid £79.99
I looked at the cheaper ones but the TV is c20kg from memory and wanted to make sure it was strong enough.
I have it mounted on one wall and then articulated out to sit "angled" across the opening like in your first "sketch"
E: picture here
https://www.overclockers.co.uk/forums/posts/33344059/
E2: Just checked - 31kg
