Deleted User 298457
Deleted User 298457
I vote this guy my favourite member
Do not start chasing out the mortar. Leave it alone, it's doing important work
Use mini trucking along the skirting to the corner and then up to the TV. You'll find something suitable on Screwfix https://www.screwfix.com/c/electrical-lighting/cable-management/cat1150038
Absolutely chase in, trunking looks horrible.
I HAVE TAKEN THE SKIRTING BOARD OFFI have put cables behind the skirting board before, just take them off, sometimes there is enough room behind them already, otherwise just scrap/knock a bit of the brick away.
Coming out of the skirting near the sockets just drill or chisel out a hole or small channel depending on what the cable is, them fill any noticeable holes.
From the TV down to the skirting, either a bit of trunking but as its a small run you can make a channel in the brick, put cable in but in some trunking so the cable isnt sitting in any wet mortar/filler etc. fill and paint, should look ok with it being white and the brick, you can even smooth some the mortar joints back in with your finger when whatever you fill the channel with is still a bit wet.
You can get some damp paint to cover those patches, then paint over again with the paint you have on now, check what might be causing the damp though, look on the outside of building in relation to the inside patches. Sometimes it will be very obvious.
It'll look worse before it looks better - looks you have a great way to route the cables really painlessly! I'm sure I'll get shot by someone (@200sols) but I would put a nice new thick skirting up and then mount your sockets to the skirting without a backplate.I HAVE TAKEN THE SKIRTING BOARD OFF
Holy living christ it is terrifying behind there.
I was literally pulling out rocks.
Question. Can I cut into the brick and make the plug flush to the wall? Or do I need to have a "professional" do this?
Here are some scenes from behind the skirting board.
I mean is that something I can do myself?It'll look worse before it looks better - looks you have a great way to route the cables really painlessly! I'm sure I'll get shot by someone (@200sols) but I would put a nice new thick skirting up and then mount your sockets to the skirting without a backplate.
Yeah I said that when he mounted the inspirational quote boardI didnt see it was a brick wall, in which case I favour the industrial look. Exposed gunmetal trunking, industrial sockets etc. Shame the wall is painted horrible white but such is life![]()
