Entirely possible it’s either a capacitor or as suggested the entire power board. Replacing either wouldn’t cost that much and really isn’t too difficult. The power board would be a few screws and some connections to remove and replace. The capacitor is a little more tricky, but if you’re any way handy with a soldering iron it’s entirely doable.
I fixed a friends TV a few years back with a spare power board sourced from eBay.
If it was my TV I’d have it off the wall and strip it down for a good look around. Dodgy caps will be easy to spot as they normally dome at the top.
No way I’d be binning it until I’d tried everything.
Edit - one other thing, not sure if it’s been tried/suggested, but might be worth removing the batteries from the remote and trying the physical buttons on the TV, just in case the remote is defective. Some remotes can work from another room so removing the batteries is the best way to be certain.
