Was looking at photos of the backside of the tv power board and think iv worked out what the thermistors do. They seem to feed current to the larger high voltage capacitor bank on the side of the board. Once a certain voltage is reached the relay next to the thermistors activates and shunts the thermistors bypassing them from the circuit and giving full power to the caps?. Some sort of soft start system that might be used to lower the strain on the bridge rectifiers?
Trying to work out why it would have failed.
The old working thermistor had 38% higher resistance at rest than the brand new ones.
So i wonder if the older thermistors have degraded with age and gave higher resistance therefore taking longer to charge the caps to the level where the relay takes over to bypass them. If thermistors are working at full tilt for too long they probably got mega hot and popped. I do believe they didnt pop at the same time since loud pops were heard on 2 occasions.
What i don't get though is why this sort of situation would prevent the tv from turning off. The situation makes sense for a non start or overload situation causing main fuse to pop, its strange.
