Right so spent the morning and most of the afternoon as promised trying to get a rounded feel of both CPU's with the objective of proving that at matched settings the 1700 and 1800x are practically the same.
So first up the parts I used
The settings for both and the pit...
Voltages are a bit over recommended because I couldn't get the 1800x to do what it is told
but they are achieved by putting 1.5 in the bios and then load line calibration at max
1.45 is just a no go for 4.0 @ 3000 on the 1800x it's early days any number of factors could be causing the issues.
The raw screen shots are in the imgur link at the bottom these are edited together to show the bench marks should have used 1080p with hindsight.
1700
1800x
As you can see the difference seems to favour the 1700 but only marginally it would appear that the 1800x is a great chip if you just want to set the memory clock and let XFR do it's thing, but you can if you want to save some money on a cpu and spend some time get similar performance from a 1700 maybe in a few days when people have had a chance to play with their parts we will have a bigger picture.
other things worth mentioning are the super flower 550w i was using had no problem with the system averaging 200w power draw upto 300w in gaming W
Link to full album is here
http://imgur.com/a/Cz2Di
1700
1800x
