** UK FIRST - BITFENIX RECON FAN CONTROLLER **
  • Thread starter Thread starter rjk
  • Start date Start date
In two minds to send it back unless bitfenix can make a fix and fast..
It's a pain but not a deal breaker for me as I will never need to control the fans apart from on the pc. It would be nice to be able to control them from my pc rather than reaching under the desk which it should do..
Will see if anything comes up about it from bitfenix.
Cool at least it's working now. It's a superb controller I'm really impressed I can monitor my pc's temps and adjust accordingly from the toilet... :D
The novelty will wear off soon as it's a pretty pointless feature really.
I think it's pretty cool because it means I can internally fit it and then control everything from my computer and it's miles cheaper than an aquaero.
Controlling from your pc is ace as it's far easier than using the unit if your pc is under the desk. Adjusting the fans from anywhere is a bit of a gimmick though.
Yeah, I really can't see a point when you'd want to control it from anywhere. With the exception of if you were demoing an insane mod you could stand next to it with a tablet and control it without having to bend down and fiddle with the unit all the time.
