I was having a look at radiator mounting options in my case, and although I can fit a slim triple rad across the bottom 2 fans I wondered If I had other options.
Here you can see the size of a regular 120mm fan next to one of the monsters
Notice the mounting holes on the fan bracket so I could in fact fit a twin rad directly to 2 120mm fans for possibly better pressure through the rad. Not only that but it also gives a little more clearance from the bottom of the gfx card and even more If I were to use a couple of 20mm thick yate loons.
Currently just whipped my corsair H50 out to try my old thermalright 120 and actually getting just as good temps as the H50 - looks a mess at the minute but purley for testing!
