== Ultima Divinity - Flagship Level 10 Designer System ==
once it is built i will post up pictures of it
put it this way, the guy building it is that impressed he is buying one once we get another shipment! :eek:
wow, the case looks like a pain to work with, need alone the cooling
'Custom' Ultima Divinity
this particular system has an Intel 975 in it
will update when its finished
Cheers for the photos :) Thought it was gonna be dead wierd inside for some reason, but its basically just a mobo tray with boxes covering the various components, not as complicated as I expected lol.
I do like that case, just couldnt justify spending that much on it :(
Yup, pretty much a board with a tray on it with some boxes slapped over the components, and a handle.
Really don't get why the case itself is so expensive, then again bmw supposodly had a hand in it so i suppose that explains the extra cost. :confused:
this is a quick screenie of work in progress to give an example of the running temps
we are still getting the clock stable at lower volts which is dropping the temps significantly
I dont have a lot of experiance in high end computer temps but this temps seem quite high for watercooling...
Hello,
I am new on your forum.
I am in PARIS in FRANCE.
I have had a LEVEL 10 for a few weeks, and I must say it is not easy to find a "radiator" powerful which returns in this case :(
I' bought a CORSAIR H50, and I can say it cannot to install as on the photographs because a plate interior on the door obstructs then closing:mad:
Dimension for a radiator cannot exceed 157 mm since the base of the core, Mégahalems and the NOCTUA NH U-12 P SE does not return for 1-2 mm…. If you have the solution, do not hesitate, I am taking… :D
Thank you,
XPro
the h50 does fit?
i cant really understand what you are on about?
could you be more clear?
The CPU cooler does NOT exceed 157 mm heigt in this case and it's impossible to assemble the H5O corsair with two ventilators in push-pull, as on the photographs, because the case cannot close any more … a metal plate blocks closing. :(
It quite obviously does fit looking at the build pics.
It looks like its set-up in a push-pull config as well, so I'm not entirely sure what you are referring to.
No, it's impossible as the build pics, i have a LEVEL 10 at home ...
I have tested this assembly, two coolers with the H50 in extraction, it's too much large, i can't close the carry side ...
