== Ultima Divinity - Flagship Level 10 Designer System ==
ok chief - whatever makes you happy...
all im saying is i have built 6 of these things now...
all with h50s
all in push pull
argument over
we will finish by the knowledge which you have built 6 of these things now...
Perhaps you want a medal?
What I ask, c' is a little helps; … OK is all.
For this moment you have not make advanced the debate…
Can you show precise photographs of your assemblies ? ... perhaps ... No ?
Why would he have photos of his assemblies? One of his is on the first page, about half way down. It clearly shows that the H50 fits.
Is the filter meant to be there? The stand offs do not line up with anything.
Oup's same that ...
Here is the metal plate which carries a filter and which returns to interior of the case and which will come to place itself partly in front of the back fan after the closing of the door… you see?
My photographs also show that H50 passes, but with the open door but… not closed ....
My H50 is assembled same manner that yours… and yet the door will not be closed completely…
You have been a bit of a plonker. If you look here:
The filter goes outwards though the hole, so you have obviously unscrewed it and put it back the wrong way around at some point.
I know, I have not dismounted anything, just the outside plate ... ok ?
LOOK :
Inside,
Outside ... the same metal plate ...
You see ?
I can see what you mean, but if you look at rjkoneil's post on page one, it looks like there is a little cover that goes over that, so he might have it on the right way.
Who knows but I find it strange that he is arguing with someone who builds these professionally :p
Obviously you cannot reply now, but is there supposed to be a gap between the side panel and dust filter? It's not going to be effective at stoppong dust if there is a gap the air can just go through. Are you sure you haven't taken it off and put it back on the wrong way? I mean it looks like you took it apart in earlier photos so I assume you have taken it off. Try flipping the fan filter around so its flush with the side panel. If you didn't do it wrong it could have been done at assembly. I've had weirder things on some of my cases...
I know you cannot reply but still. There is enough ideas you haven't acknowledged or entertained the notion of in this thread, if it's not covered and you cannot fix it I suggest you contact Thermaltake, as it should and does fit for other people, your case is likely faulty in it's design. But I suspect it is something you have done. Hell just push the door a bit harder, it's not really going to break, it sounds like this case is poorly designed to begin with, so I'm sure you are glad with your purchase. :p
I think something is being lost in translation! Seems pretty obvious his configuration has something different about it hence it not fitting, good luck working out what that difference is though ;)
