Permabanned
- 10 Nov 2005
You obviously don't know how it works then. It's cheaper for them to refund him as it won't have been worth very much, versus fixing it with all new everything and giving it back.Why would they go through all the effort of refunding and then trying to sell it again, if they were already in the position of being able to "order the new injectors/any parts it needs for **** all at trade price"
The more likely scenario is:
"Then once you've left, they'll delete all the fault codes, do a quick & dirty bodge fix and put it back on the forecourt and sell it again, hoping the next poor sap to buy it is easier to fob off. Joys of a mainstealer/dealership."
They'll just get stuff stupidly cheap new or used, and often have a pile of broken cars that share the same engines/parts out the back to salvage/stock on hand, fix it again and sell it for the same or more. That's how it works with dealerships and main stealers.
You cannot lmfao just wipe fault codes and magically make injectors work again, and a bmw fault code will come up nearly straight away and put it in limp home mode and light up the dash and cut throttle.
