- 21 Jan 2010
Put up a sign saying "do not throw stones at this"
Damn that's pretty stupid
Looks a bit like a very old oil filter from a tractor.
Who moved it?!
I did.
diesel filter? from the first pic maybe... don't think so tho
e: ... https://thefarmingforum.co.uk/index.php?threads/fe35-23c-oil-filter-housing.235002/
maybe's
I always wonder why anyone thinks that a bomb from either 100yrs ago or like 80years ago won't have degraded so badly that they would still explode. I appreciate being sensible and cautious but is it entirely necessary?
Anyone with a chemistry degree like to enlighten me on how nearly a century of degradation doesn't make these things more useless than the time they failed to go off?
Does ammonium nitrate or TNT somehow remain explosive?
They didn't necessarily fail to go off - it might be stored munitions which got buried, etc. and later turn up. The explosives and primer, fuze and whatever are generally fairly protected from the elements, etc. so take a long while to degrade. Stuff which failed to go off can be more dangerous as they could be one knock away from not failing to go off and even degraded munitions like the state this object is in have been known to still pack enough punch to blow someone's hand off.
The science is beyond my working knowledge but people regularly test 100 odd year old ammunition with mixed results but a lot of it still works fine or works with reduced performance.
I'm surprised no one has tried dropping that big stone in the background on it.
Yup.. I used to use .303 rounds with production date codes on the headstamp of 1942. Was as reliable as much of the modern .303 as well. Just had to clean the gun a lot more thoroughly as it was corrosive to the barrels. Got strange looks pouting boiling water into a funnel and down the barrel.![]()
Look up the Iron Harvest.
A controlled detonation has been carried out on an unexploded World War Two bomb found in Exeter.
More than 2,600 households and University of Exeter halls of residence were evacuated after the device was found on Glenthorne Road on Friday.
Every year, an estimated 2,000 tons of World War II munitions are found in Germany, at times requiring the evacuation of tens of thousands of residents from their homes.
