I bought a broken 360 from a member of this here forum, I've sent it off for repair so hopefully the guy can fix it for me
But the xbox has no hard drive or memory card, and (excuse the caps, but) ARE THE HARD DRIVES A RIP OFF OR WHAT?!! £70 for a 20gb hard drive... you can get a 250gb hard drive for almost half that!
So I figured I'd get a memory stick, if the box is repairable, as it's a much cheaper alternative to a hard drive. But even then you're paying £20 for a 64mb chunk of memory...
I figure unofficial hardware would be cheaper, but I can't seem to find any?
Can you get unofficial hardware for the 360? Or somehow get a PC hard drive onto the 360? Or anything that means I'm not getting ripped off for memory?
Cheers!
Cheers!
