- 25 Nov 2011
- The KOP
Unreal engine 5 showcase
Gaming just got a whole lot interesting with this engine, especially for those on last gen GPUs as with this level of detail and performance budgets, not everyone will need a 3080 or above to experience true next gen gaming.
Valley of the Ancient is a separate download of around 100 GB. If you want to run the full demo, the minimum system requirements are an NVIDIA GTX 1080 or AMD RX Vega 64 graphics card or higher, with 8 GB of VRAM and 32 GB of system RAM. For 30 FPS, we recommend a 12-core CPU at 3.4 GHz, with an NVIDIA RTX 2080 or AMD Radeon 5700 XT graphics card or higher, and 64 GB of system RAM. We have successfully run the demo on PlayStation 5 and Xbox Series X consoles at full performance.
Ray Tracing does not work on standard Nanite assets, you have to use a proxy mesh to use Ray Tracing.
UE4 may not be favourable towards AMD, hopefully UE5 is more balanced.
AMD partners with Epic Games in Unreal Engine 5 Ea... - AMD Community
Lumen's Global Illumination and Reflections primary shipping target is to support large, open worlds running at 60 frames per second (fps) on next-generation consoles. The engine's High scalability level contains settings for Lumen targeting 60 fps.
Lumen's secondary focus is on clean indoor lighting at 30 fps on next-generation consoles. The engine's Epic scalability level produces around 8 milliseconds (ms) on next-generation consoles for global illumination and reflections at 1080p internal resolution, relying on Temporal Super Resolution to output at quality approaching native 4k.
Nanite is currently limited to rigid meshes. These represent greater than 90% of the geometry in any typical scene for projects and is the initial focus of Nanite development. Nanite supports dynamic translation, rotation, and non-uniform scaling of rigid meshes, but does not support general mesh deformation, whether it is dynamic or static. This means any position of a Nanite mesh in a way that is more complex than can be expressed in a single 4x3 matrix multiply applied to the entire mesh.
Deformation not supported includes, but is not limited to:
- Skeletal animation
- Morph Targets
- World Position Offset in materials
- Spline meshes
- Nanite meshes also do not currently support:
- Custom depth or stencil
- Vertex painting on instances
- This specifically means per-instance painted colors using the editor's Mesh Paint mode.
- Vertex colors imported on the original mesh are supported.
The following materials, with the following settings cannot be assigned to Nanite meshes. They will either be disallowed or will have no effect on Nanite meshes if used.
- Any Blend Mode besides Opaque
- This includes Masked and Translucent blend modes
- Deferred Decal
- For example, using a Nanite mesh for Mesh Decals
- Decal meshes projected onto Nanite meshes is supported
- Wireframe
- Pixel Depth Offset
- Custom Per-Instance Data
- Two Sided
- Materials that use the following will not render correctly when applied to a Nanite mesh and may appear visibly broken.
- Vertex Interpolator node
- Custom UVs
The following rendering features are not currently supported:
View-specific filtering of objects using:
- Scene Capture with:
- Hidden Components
- Hidden Actors
- Show Only Components
- Show Only Actors
- Minimum Screen Radius
- Distance culling
- Anything filtered by FPrimitiveSceneProxy::IsShown()
- Forward Rendering
- Stereo rendering for Virtual Reality
- Split Screen
- Multisampling Anti-Aliasing (MSAA)
- Lighting Channels
- Raytracing against the fully detailed Nanite mesh
- Ray Tracing features are supported but rays intersect the coarse representation (called a proxy mesh) instead of the fully detailed Nanite mesh
- Some visualization view modes do not yet support displaying Nanite meshes
Fast camera movement will cause Lumen Scene updating to fall behind where the camera is looking, causing indirect lighting to pop in as it catches up.
Lumen Surface Cache covers the 200 meters from the camera position. Past this, only screen traces are active for global illumination.
Lumen Global Illumination cannot be used with Static lighting in lightmaps. Lumen Reflections should be extended to work with global illumination in lightmaps in the future, which will provide a way to further scale up render quality.
Foliage is not well supported in this Early Access build because of the heavy reliance on downsampled rendering and temporal filters.
Lumen's Final Gather can add significant noise around moving objects and is still under active development.
Translucent materials are not yet supported for Lumen Reflections.
Translucent materials will not have high-quality dynamic global illumination.
Next generation games haven't even started yet.
The enviroments are a great but the player model is lacking and stands out in a negative way compared to the rest of the scene.Unreal engine 5 showcase
But 2.3x the performance is something. It shows how costly is native rendering vs upscaling. And it proves it can be done without "dedicated hardware".
I don't think you get 2.3x the performance with DLSS performance ( or whatever the setting is to turn 1080p into 4k ).
That or they overclocked a 3090.Its called performance mode. the uplift depends on how long the frametime is, the longer it is the better the uplift. to get just 4k 18fps in unreal engine 5 is quite low, probably a 6900xt they used to test it?
That or they overclocked a 3090.![]()
Yeah but they say the TSR is activated by default so if you overclock it, then you may get 43 FPS.Nope 3090 gets better performance than they quoted. The unreal engine 5 beta is now downloadable on the Epic website and this tech demo can be loaded up and played - my 3090 at 4k all settings max sits between 31fps and 42fps
