Yeah but they say the TSR is activated by default so if you overclock it, then you may get 43 FPS.
Really who cares what card they used? The performance uplift is what counts so if you get 40 FPS instead of 20, that's 2times the perf of native. In their case it is 2.3times more.
But 2.3x the performance is something. It shows how costly is native rendering vs upscaling. And it proves it can be done without "dedicated hardware".
I don't think you get 2.3x the performance with DLSS performance ( or whatever the setting is to turn 1080p into 4k ).
They have a single screnshot with TSR and it doesn't look too bad, if it won't make bad artifacts then it should be good at least for consoles and older hardware. The perf increase is around 2.3X (from 18.6FPS native 4k to 43FPS upscaled from 1080p).
I am sure some reviewers will try to convince us how bad the TSR is on this engine because DLSS is a big selling point for Nvidia and it is built on a lot of marketing BS about AI and neural networks, but for me the TSR looks the same.
Have read that apparently with TSR on, motion is horrible?
* However, as soon as the camera moves the image completely degrades down to 1080p quality
So Lumen is worse than RTGI since you need a pretty powerful card to get to 30 FPS with "DLSS" set to performance.By the way, I found this interesting.
This is the recommended system specification for running Unreal Engine 5 and this Valley of Ancient demo at 30fps (super resolution on)
CPU: 12 cores at 3.4ghz or better
GPU RTX 2080 or better. 5700xt or better (needs to support Shader Model 5.0)
RAM: 32GB RAM or more
Storage: SSD, faster the better
Wait until Nvidia will put their dev tools inside UE5, it will cut the AMD perf by half.The valley of ancients demo appears to run faster on amd hardware. I've only got a small sample size though, there a YouTube channel that has put up rtx3090 video and one of the 6900xt video. The 6900xt appears to be averaging 10% higher fps
I was talking about the perf hit. If Lumen can work at half the cost of RTGI, then it is already a win.
Epic needs AMD for their engine to be optimized for consoles. But for PC's the UE5 games will be made with a lot of plugins from Nvidia so there is no reason to worry.
Plus if the demo is upscaled from 1080p by default, then it is normal for the 6900xt to be ahead even in "4K".
speaking of Nvidia dev tools lol, it's confirmed Nvidia and Epic will also be adding DLSS, RTX, Reflec etc and Nvidia optimizations to the engine https://wccftech.com/nvidia-reflex-support-already-in-ue5-dlss-support-coming-soon/
