Upgrade for gaming - rebuild or new system?
Assuming you are using google chrome as your browser then do the following :D
Ok add all the parts to your shopping basket as normal. When you have everything in it then click on 'view basket' at the right side of the screen.
Then look at the very top right of your screen and there should be a little 'clipboard' type icon.
Left click on the clipboard icon.
Then click on reply to thread in here, and then 'right click' your mouse and select 'paste' with the left button.
The basket should then appear :D (Hopefully lol)
No problem, glad to be of assistance :)
One other thing. The Gigabyte Motherboard has a Free Corsair Raptor headset with it whilst stocks last.
Also the Asus graphics card has a Free Asus headset with it, so if you are ordering 2 cards you should get another 2 headsets.
So you should get 3 Headsets in total :D
You might be able to get the value of them knocked off your build if you don't need a headset, so it might be worth asking.
ahh nice thanks for that, I don't need the headsets I have 3 already. But ll try and get it reduced like you said and if they won't do that maybe I can sell them on ebay or something :)
Its done!! I have purchased it with the retail cpu thats due out on the 23rd. There building it for 60pounds which is good. He said he wouldn't overclock the new cpu but he said it would be good enough.
I just want to thank everyone for helping and taking the time to give help and advice on this!! cheers guys and all the best.
