Upgrade Help Please
I never originally suggested a crossfire motherboard, that psu is for my spec.
and you always go on about how it can output 450w! so its better value than the vx450
Ah! OK! I agree with you. Sorry about that.
Going for the CX400W would mean the OP could get a more expensive motherboard for the budget too.
You may want to order an additional 120mm fan for the case.
Ok Thanks, well thats the case sorted.
Not sure whether to stick with intel or go amd if i stick with intel i could buy a good mobo than but my Core 2 duo in and upgrade my CPU in the future where as i'd have to buy a slighty crapper mobo and cpu if i went AMD.
EDIT:
Would a fan like this http://www.overclockers.co.uk/showproduct.php?prodid=FG-024-AK&groupid=701&catid=57&subcat=4 be fine or this http://www.overclockers.co.uk/showproduct.php?prodid=FG-056-AK&tool=3 because it lights up (Y)
If you are going to buy a newer mobo for your current CPU then your buying older tech. Buy a 890 AMD chipset board and that will be future proof for a few years.
The sharkoon fans are well regarded.
http://www.overclockers.co.uk/showproduct.php?prodid=FG-005-SH&groupid=701&catid=57&subcat=4
This is a 120mm fan round-up.
http://www.bit-tech.net/hardware/cooling/2009/09/28/what-s-the-best-case-fan/1
Not sure what to suggest about your build, only you can decide if you can really afford one of the suggested builds, or just a new motherboard for your existing system.
But I do agree with the above post, make sure its got the newer 8** series chipset.
The AMD 955 CPU is not crappy.
To be perfectly honest.
I don't believe you would notice the difference between DDR2 and DDR3, you would need to use a benckmark program to see the actual difference.
The issue with buying a lga775 socket motherboard is the fact your spending money on a dying/dead socket.
Is your budget still the same as your first post?
You could just buy a new cpu, motherboard and ram, and use your existing psu untill you can afford to change it.
hmm, ok.
My budget is still around the same but i havn't got round to finding my bank card to check how much i have in it so its an estimate :).
The case and the fan are £53.19 so i have about £320 maybe left.
So with approximately £320.
You can have the quad core 955be CPU.
The OCZ memory.
And a 890 chipset motherboard (gigabyte or asus).
Basically what matt has in his suggestion above.
The OCZ memory.
Ok, thanks when i find out how much money i have i'll post back and i may be able to borrow some so i can stretch for that HexaCore
I would be intersted in doing a deal for your e4700 i have a brand new akasa 850w power supply that i have for sale. If your intested in deal. see my review on overclockers
As nice as that sounds i think i'm going to keep my power supply for now and see how it goes and sell my e4700 for cash.
